Recording from guitar amp thru mixer into comouter
  • Thread starter Thread starter stewrose
stewrose
Is it best just to put a mic in front of amp to record or is there a D.I kind of setup I should use. I record into an an analogue mixer then thru a sapphire pro audio interface into Ableton Live on my PC
put a mic in front of an amp speaker. A shure sm 57 works well.
In my opinion that yields the best result if you are getting a good sound out of the amp. You have to be in an environment where you can crank the amp volume up. If you can't really do that direct recording can work well too.
All my guitar work on this tune is direct and it dosent sound too awful
https://m.soundcloud.com/jimistone/voodoo-child
As a general rule mic/amp is the preferred method. Sort of depends on having an amp worth miking, and a mic worth amping, so to speak. What do you have, gear wise?
The speaker and cabinet are part of the guitar amps sound. Going DI bypasses them, so you would need to do something to compensate for that.
Mic is prefered. If you aren't in a situation to do that, do what you can.
Why do you have the analog mixer in the sound chain? If you are getting a sound you like from the amp, and mic it correctly, that is exactly what you want to be recorded.
SM57 to Focusrite Saffire interface. Don't use the mixer unless you have a very good reason.
