After experimenting with different approaches, my band seems to have settled on recording by running direct into our powered mixer head (we don't have a dedicated mixer to record through), and using the mixer's recording outputs to go into a digital multitrack, which feeds a headphone amp. We record our basic parts altogether, to keep that "live" feel, and overdub sparingly as needed. This approach is working pretty well, with one exception: It's difficult to get enough volume from the Yamaha DT Express II drum kit our drummer uses. The bass, guitars, and vocals are all fine, volume-wise, but the gain control on the mixer has to be cranked up almost all the way on the channel we're using for the drums, and even then they're a bit low. The drums are connected to the mixer through a standard 20' high impedence 1/4" instrument cable, as are all the other instruments.
Would a active or passive DI box help bring up the level of the drum signal (I don't own one, so I'd have to buy one to try this approach)? Does the drum signal need to go through a separate preamp to increase its level before it reaches the preamp in the mixer? Any suggestions would be welcomed!
