Blue Bear Sound
Minimal signal path is usually a good rule to follow.... don't put anything in the chain unless it needs to be there...
er, yeah..... that's what sound engineering is all about! You think you can just slap a couple of mics up and call it a day?????Disposable said:...but it takes a lot of work to adjust the sounds to get the sound I want...
Blue Bear Sound said:No - far lower than that.... a guitar amp has a steep roll-off after about 4KHz....
Mostly between 1.5KHz and 3KHz....grinder said:Is the distortion buzz at around 4Khz?I thought guitars rolled off more around 7-8 khz but, I don't have an RTA.
Blue Bear Sound said:You think you can just slap a couple of mics up and call it a day?????
Cyrokk said:http://www.homerecording.com/bbs/showthread.php?s=&threadid=64239
The post from Pipelineaudio is where you need to look.
Also, if anything in your recording chain allows the use of batteries, then use them instead of an adapter.
Cy
slabrock said:Never record distorted guitar D.I. - never. There's an absolutely brilliant album by the Husker Du called 'Metal Circus' - listen to that for what i told you. Brilliant album - all guitars D.I.'d straight to the console thru a Distortion+ and it sounds unbelieveably bad. Brilliant record, though.
Cyrokk said:I'm gonna hafta respectfully disagree on the ... the combination of a mic'd guiitar and a guitar recorded through, say, an RP-100 tweaked to the proper degree can yield quite good results.
I said the same thing about modelers a year or two ago. Above all else, they're devices for saving time and money in production, and they do that remarkably well. If you look at them that way and spend some serious time at home doinking around with profiles in a computerized editing program (such as J-Station's "J-Edit"), you can eventually catalogue a number of useable basic sounds for your specific personal instruments and really fly when you're in a situation where time=money.slabrock said:Then again, i have used a Pod Pro in studio several times and probably will again. It was after a sound engineer explained me for the tenth time, that i was a fool to come for a 2 hour session, and spend 3 hours setting up a 1967 plexi-marshall for distortion, a 1970 Fender Princeton for clean etc. etc.
