P
Pen
This will be my first time recording drums and wanted to get some advice before I give it a whirl. I've done a fair amount of reading here and realize that the ideal scenario would be to run the mics into a unit with like 7 channels. Like I mentioned, I'm new and not at the point where I'll be upgrading equipment anytime soon.
mic's: Shur 57's (we've got 7 of these) - I can borrow one Audix F-15 condensor mic if needed. I've got a few shur58's floating around as well
Interface: Tascam US-144mkII
Laptop w/ cubase LE5
mixer: If needed, I can use a 12 channel mixer and mix the drums pre-interface.
Rooms: Soundproofed - but in a basement. I believe the ceilings are 8 ft - not a huge space - but not tiny either.
So, I'm looking to record the drum track. As I'm no drummer, I'll be travelling to my drummer and having him put the track down so I can do the rest at my place. Obviously I'll be bringing my stuff to him and setting up at his place.
As I'm limited on equipment, I'd appreciate any advice so I can get the most out of what I have. Here are my thoughts/options so far....
-Use 1 mic (the condensor) place about 5 feet in front of the drums. Run this mic feed right into my Tascam.
-Mic each drum individually w/ the shur57's and then run those feeds into my mixer. Get the mix right and then run that 1 line into my Tascam.
-Record each drum individually 1 track at a time (although, I'm worried about bleed over and synching the tracs here).
Goal: I realize that this is going to sound amateur as it's my first go - and my equipment isn't pro quality. I would like it to sound balanced. Also, the song (an original) would be catagorized hard rock w/ the drums forefront (similar to led zep - or foo fighters).
Thanks!
Thanks!
