I just remembered I recorded a kit with two Mic's a couple of months back, and here is what I did. . . . .
I think its important you get a stereo pair going on, your never going to get a really strong kick and a tight snare. But having a good stereo image will really help sound bigger in the mix.
I set up my 2 SE1a's in a near coincident position like this < (so the diaphragms are pointing away from each other) opposed to a coincident set up like this > (where the diaphragms cross each other) because you get a wider image with a NC set up IMO.
I set the Mic's so the height of them was just poking over the top cymbal, angled down slightly, placed directly central of the kick. then I moved them a few feet away from the front of the kit. This way you are covering the full dynamics of the kit. With this basic setup I could then listen to how it sounded, I found that If I moved the Mic's further away I got more kick punch, closer would get more sizzle from the cymbals. and by positioning the snare side Mic so it directly pointed at the snare, it isolated it a bit more, getting a little more presence, and also helping to balance the level with the Hi-hat. this position is worth trying, the tricky bit was getting the distance, hight and angle exactly right, to match the balance I wanted. But I did walk away from the session with a great drum recording, perfectly usable. a good powerful kick, sharp snare, and a good tom roll and cymbal separation .
pan the tracks left and right, do a bit of careful EQing to bring out the pieces you think are lacking, a tiny bit of light compression just to help tighten it up. It was a decent kit, but possibly the worst room I have had the displeasure of recording in.
Hope this helps
