recording bass?
  • Thread starter Thread starter metaljoseph
metaljoseph
metaljoseph
Dedicated Member
Do you guys prefer D.I. or micing when recording bass. So far I have only been going D.I. and am mildly impressed with the sound. Is micing better and more powerful? What is a good mic for bass?
i've never tried micing my bass.
i always D.I.
i may be wrong but i've always felt direct lines with stuff really kills high end but i've never had a problem with bass. i don't know why that is.
I always record bass both with a DI and a microphone.
The mics I prefer are AKG D12E, Sennheiser MD441 or MD421, Beyer M88, Neumann M149, MXL V77S, Studio Projects B1 and sometimes a Beyer M260 ribbon.
I mic the cab and also send it through a D.I, so i can blend my mix according to how i want it. Whether i want more "dirty" sound or "clean" sound, depending on the song.
Mics i use are: AKG D550, AKG D112 or Sennheiser 421
Another vote for "dual mode" bass recording.
Try close micing with a D112. Sounds amazing on our bassplayers ampeg 4x10.
This might be extreamly unpopular, but this has worked in the past (sometimes). Durring ine session I ran out of mics, but stilled wanted to do the bass di/mic thing. So I went to the back and found a SM57. I miked it just like a guitar amp (stright on the cone) and mixed it with the DI. The sound was a bit more edgy than i usually like, but it's kind of a cool tone.
I usually print a DI and a mic on the electric bass. I will decide what combination (both, just DI, just MIC) to use in the mix.
If I am tracking something for someone else to mix, I will for sure print both a DI and a mic, and maybe an alternate mic. Make sure the phase relationship referenced to the DI is good on the mic side of things, or you can wind up with a less than impressive bass sound. When you finally capture a really "focused" bass sound with a good mic, a good pre, a good DI, and a good player with a good amp: it gets easier.
I love the new neumann dynamic on bass, and I always seem to use a blue mouse, or an RE20, or a FET47, or a TLM170 "gotham."
I actually like the 4033 a lot on bass when someone has an edgier sound....
i didn't know there could be phase issues with DI and mics until my last recording. the 421 (sweet spot on cab) and the 4050 (cardioid - 4' or 5' back) were fine but the DI was like 90 degrees out of phase and sounded ... yuck.
next time, should i move the microphones more? how does one eliminate DI + mic phase problems?
On some occasions I actually love "triple mode" with an extra condensor near the right hand of the bassplayer, to pick up some string noise. If you are working with a bass/amp setup that isn't all too clear in the hi end, but you still want a more lively sound, than the third mic could really add a more natural feel to the whole.
Be advices, it's not worth it on most productions, even with a not-so full mix, but on a solo, or just a quick impressive fill, it has worked wonders for me.
Yeah how do you get phase issues between mic & DI when close micing?
At 1 foot/mS, if the mic is 1 inch from the grill, at the most there will be a delay of 1/10000th seconds between the 2 signals. Is this enough to throw things out noticeably?
You will end up with a little more delay than that because the DI has a much more direct signal path. That delay will throw things off. You just have to line the tracks up in your daw.
Just adding a "me too" to the DI-mic'd bass. I've used my Beta 52, 57 and D112, all with pretty decent results.
my 2c......
If recording digitally, you can just zoom in on the waveforms and manually align them. Otherwise, you'll just have to mess with different miking distances.
You could also invest in a Little Labs IBP or IBP Jr, or use a digital delay to delay the DI signal the appropriate amount of time, if you can determine it.
There's nothing you can't mic with a 57.
can anybody recommend a DI box? I usually use a line out or direct out from the amp... but when you guys say you record "DI" that really means that you're using a signal directly from the instrument, correct?
can somebody clear this up for me?
thanks.
Another vote for dual mode. Just recorded a P-Bass through an SWR workingman's 15, using the direct out on the SWR through a Toft with some mids pushed blended with an Audix D6 on th cab through an old Altec. Pretty killer bass sound if I do say so myself.
thanks.
In my understanding, to DI a bass, you need some sort of preamp to convert the instrument level signal to a line-level signal and you need to convert the high impedance of the instrument to a lower impedance signal. A preamp with a DI section accomplishes both. A DI box alone only takes care of the impedance, but does not amplify the signal. Personally, I use the Groove Tubes Brick for most DI/preamp duties, as it sounds sweet on bass.
Using the line-out from your amp is fine as long as it sounds good to you.
