B
bohunk06
I am trying to get a better bass sound and am having some trouble. I am relatively new to recording so I might be missing the obvious. For a while, I was recording direct into my FirePod and using Cubase Studio 4 as my software. The bass was coming out kind of weak. I tried EQ and compression, but just can't get a good, smooth bass sound. I read a little and thought that it was because I needed a direct box. So I just went out and picked up a Live Wire Passive Direct Box. I think I understand about it converting high z to low z and unbalanced to balanced and all that. But it doesn't sound like its changing the sound at all. I thought it would thicken it up. But it sounds exactly the same. Am I missing something? Are there any suggestions for getting a smooth, thick sounding bass using Cubase?
Thanks!!
Thanks!!
sound to work with.I like to combine a di signal and mic'd cabinet. Like was mentioned a beta 52 is great. compression helps a lot. I tend to cut bass in the 200-500 hz range, just like a kick to take away the mud.Then as far as what eq to boost it all depends on what is needed. How about some samples?
