Apologies if this question was covered another threads. I'm trying to grasp a little more solid knowledge about using EQ.
I'm currently using Reaper and the RealEQ vst. I've read a number of tips on EQ but I wanted to make sure I'm on the right page on some points.
When someone mentions to cut, or scoop certain frequencies, is this shelving? If not what exactly does this mean?
When it's mentioned to boost to a certain frequency, does this mean using a band and bringing it up to a specifed number? Such as "kick drum, boost at 80hz?"
I also read a tip with regards to adding EQ to your tracks, which states: "Low cut everything as high as you can get away with (sometimes up to 500Hz or more), except kick and bass which you should also low cut, but only to around 30-40Hz."
Would this be on top of adding eq to individual tracks? I know EQing can be very subjective so perhaps it's up to my own ears and this is a silly question. Just looking for a place to start.
Apologies again if these questions seem far too elementary.
