recording 2 tracks at once - HELP PLEASE!
  • Thread starter Thread starter Greg_L
G
Greg_L
Banned
i have a tascam us-122 and cubase le. how do i record 2 tracks at the same time? is it possible? ive read the manual and hit every button on the damn thing and i cant figure it out. :confused: :mad:
guh welcome to my nightmare. yeah its possible, Set up a stereo track and plug two inputs the Tascam, one left and one right. What preferable is setting up two mono tracks. Set up one to take the input from your us 122 Left input and the other to take the input from your us 122 right input. And in theory you should be able to record each seperately and mix individually. lemme know how it goes, I got a lot of clicks and pops when I tried
okay, thank you. next dumb question: how do i tell the tracks which input to record from? :confused:
in each track's settings, you have to set the inputs and outputs how you want them. telepaul, how does one track work out? what latency are you running at?
thanks, but how? where? ive pushed every button available. i dont see how to do it. :confused:
256 methinks...lowest possible...i think it still pops, im gonna try again tomorrow. You could always direct monitor.
you guys ever think of reading a manual. They're really a valuable piece of equipment. Neither the Cubase or Tascam manuals have all that many pages, and the answers to all these questions are in there.
ive read it. several times. if the answer is there, im too dumb to see it. or, you could answer my question please if you know the answer. im not being lazy. i wouldnt ask if i could find the answer.
yeah i read the manual. I know how to do this stuff, believe me I do, but ht etheory and practice are different. I'm setting up my tracks fine but theres a buffering issue which prevents me from achieving true stereo or two mono tracks without experiencing drop outs. So, yeah I've read the manuals but they don't have all the answers.
Alright as for you, you need to set up audio inputs. This is like one of the first things in the manual; it brings you to a screen where you set up Audio Busses, and tell Cubase where to look for an input. It will be something as simple as US 122 L and R appearing in a drop down screen. I'm not at my pc right now, but its the menu that allows you to access vst instruments etc. So once youve go that set up, import a track. Choose a stereo track. Click on it and record enable. Then in the menu to the left of the transport screen, there should be input and output boxes; one will say US 122 Stereo In. You're go to record.
For two simultaneous mono tracks, add tow mono tracks, on after the other. Click the first and record enable, and in the input Box press US 122 In Left. In the second mono track, select US 122 in Right. Make sure you've record enabled both tracks then hit the big red button on the transport bar.
Look, as I said, I havnt got Cubase in front of me right now. But I know its really annoying spending money on stuff you can't get working. If this doesn't sort it out, e-mail me and I'll open my Cubase and go step by step.
so how are you recording 2 mono tracks simultaneously? thats what i cant figure out. how do i assign each track to a different input on the tascam?
nevermind. i just saw the post above this one.
HAHA! i got it! i see now. thank you so much for your help. i really do appreciate it! :D
hey thats great, good job! Can you lemme know if youre experiencing any popping or clicks?
i havent recorded anything useful yet via that method. i just set it up and tapped on 2 mics to see if i was doing it correctly - and i was. thanks again. ill try a little piece tomorrow and see how it goes. ill post my results in this thread.
telepaul:
i just set up and recorded some guitar on 2 mono tracks simultaneously. i got no popping or clicks whatsoever. it came out perfectly.
Greg_L said:
telepaul:
You BASTARD! :) Im kidding, but I'd love to know what cofiguration you have; as I mentioned earlier Ive an almost identical set up and I get pops. Whats your buffer size and sample rate ?
If you increase the buffer/latency (try 512 -- shoot for the lowest latency that fixes the problem), the pops should go away. This is more of a computer issue (& a limitation of the USB bus) than it is a problem with the tascam or cubase. There are several tutorials about optimizing your computer for USB recording (like minimizing the number of background processes, turning off virus scanning software, unplugging other unecessary USB devices, etc.).
128kb and 44.100. whatever those numbers mean. :confused:
