R
Russtopher
(if this belongs in the noob forum just let me know
All of my audio was recorded at 16 bit. This is my first experience at "mastering" something, and I know that it's recommended to master at 24bit and then dither once all processing is complete. Given that I've recorded everything at 16 bit, is it worth exporting the 2 track mix at 24 bit, "mastering" by giving a final eq, light compression, light reverb, limiting, and then dithering back to 16 bit?
I bring this up because when listening to my mixes at the DAW, they sound great at all volumes. Then when I mix down to a 16 bit .wav in Cubase LE and burn the songs to disc to listen to in the car to check levels and whatnot, I notice what sounds almost like a "flabby distortion" when I turn the volume up. Not to blasting levels, just a slight increase in volume results in what almost sounds like distortion. I don't *think* it's an EQ level, nothing sounds muddy or out of whack, and on my M-Audio DX4 monitors it sounds great. The mixed down .wav comes nowhere near 0dbs, it's usually -6 to -3 at peak.
TIA all!
TIA all!
