Recorded 16 bit, can I mix in 24 bit?
  • Thread starter Thread starter 4tracker
Hm, this is becoming confusing. Where did you guys learn all this? Is there a book or paper I can read?
My project is 24 bit, set by default in my daw settings. Some files I imported are 16bit (recorded in 1997 on adat,etc). The new ones I record (to replace a bad take) are 24. I plan to remix everything, export as a 24bit wav without dither. If/when I master, I'd dither it to 16 bit after all that processing is on the final. Is this the correct way to go about it?
Hm, this is becoming confusing. Where did you guys learn this? Is there a book or paper I can read?
My project is 24 bit, set by default in my daw settings. Some files I imported are 16bit (recorded in 1997 on adat,etc). The new ones I record (to replace a bad take) are 24. I think remix everything, export as a 24bit wav without dither. If/when I master, I'd dither it to 16 bit after all that processing is on the final. Is this the correct way to go about it?
Yes, that is all you have to do.
