I knew I was rushing when posting 2 posts ago. I've got to read things twice. 1st Marquis is correct. I'm just stcking up for my mod as I am
a tweaker. 123 are just #'s representing the mod placement on the mobo abit nforce has 3 closest to edge of board the 2,1 and one is closest to the cpu, as Marquis stated.
I love the statement all benchmark utilities give you "Theoretical benchmark does not indicate real life performance" or something like that. Fresh boot, temps etc plays a part in your scores. A grain of salt goes with it. Sysoft doesn't real take into considerstion the increased bandwith and can't or doesn't represent it of dual mark3d does a better job almost 100pt increase in my case, ut2k is what I've seen used on the abit forums. FSB seems to be better in single mode then dual. bandwith in dual.
Performance increase 3/1 vs 3/2 ...nah...I can't honestly say it will be consistant from one to another bench or board. I was mimicing a test on the abit forum and came up with different results leaning to 3/1. Can I see it...nope. Is it the same on all boards... nope. You can also fill all three slots and get dual ch. put a 512 in 3 and 256 in 2 and 256 in 1. the memory has to have very close timing characteristics. CAS Latency, Act to Precharge Delay,Ras to Cas and Ras precharge delay. You can search the meanings of these terms. to long to explain, but all the mods should be able to hanble the same settings when using 3 mods. They will most likely with what's refered to as relaxed timings but yiu lose on the compromise just for more band with. Basically it is the how long to hold info, how long on realse , how long to take and a ratio. Not so important.
http://www.corsairmicro.com/main/trg-cas.html
I've not read the above link in some time sodon't hold me to myabove interpretation
Also, it is my sense that DDR400 on a system which has a FSB of 333mhz is overkill. What I bought is that single stick of 512mb DDR400.
No it's beautiful and depending on your cpu you may be able to sync everything higher then 333. By the way the fsb front side bus is the limitation on an amd based board. Even if you are not going to overclock You will be able to have more aggresive mem timings. lower cas lat. I don't really consider ocing ocing till the voltage is touched vdimm vcore etc. I think with good equipment if you push it till you ht its sweet spot then youve only optimzed your rig.(It's still ocing though)
Don't oc unless your willing to lose hard earned cash in replacement parts. Do if you can accept the loss and get somthing out of it. Like the challenge. Performance is cheaper to obtain by buying expandable quality parts.
If you buy an nforce ultra 4oo abit may not be right for you it oc's well but has its problems. but an ultra 400 board may bwe right for you if you consider the amd road map. The barton core cpu will probably hit the 3800+ at 400mhz and keep the same package or socket format. 64 bit is expensive and not needed in the consumer market for most. Intel will probably go 64bit change there package.
ultra 400/2 sticks of Low Latency pc 3200 corsair or OCZ memory and a 2500 barton
http://www.newegg.com/app/ViewProdu...145-432&catalog=147&manufactory=BROWSE&depa=1
http://www.newegg.com/app/ViewProdu...103-417&catalog=343&manufactory=BROWSE&depa=0
http://www.newegg.com/app/viewProductDesc.asp?DEPA=1&sumit=Go&description=13-131-478&searchdepa=1
Not suggestions above but an example of a good start,goto
www.motherboards.org read up on mobos, find the forums there and read.
Marquis, "I ask because while looking at the hardware on the board, it appeared to me that slot 1 had a slightly different capacitor configuration. This could account for slightly different benchmark numbers, particularly those that are latency and/or memory bandwidth sensitive. It's also possible that under overclocked circumstances the 1/3 configuration could be marginally less stable.
This would be a non-issue at stock speeds, as I'm sure Abit has tested their hardware enough to know that'll work. but I'd be interested to see what the potential performance benefits are."
Soryy can't input on the capacitors, though you can buy some hot ones on line to oc it higher (fsb)
And I agree with you on the rest.
Julia a DAW is to be stable, I dfon't know much in that area. I'm to busy frying things to enjoy a stable setup. Good luck. Don't pay me much mind but do check out motherboards.org the forum section. I will confuse the issue no longer.......
Building pc's is only for some extra cash, I'm no pro, others here have much more knowledge, like the fella with 20 yrs experience.for sure
