quick reamp question, latency?
  • Thread starter Thread starter Slowjett
Slowjett
So I want to re-record a raw bass track through the amp using a mic. I've got my firestudio and impedance matching stuff. I want to send the signal out of SX3 via routing to one of my firestudio outs, to the amp, then back into a preamp into the firestudio. Do I have to do some sort of delay compensation or should there not be any recorded offset do to any sort of latency when doing this?
thanks!
Josh
This ain't protools....Cubase will have it all timed right. I have over 20 channels of "external" plugins running on every mix with ZERO problems. Same thing as reamping essentially.
You do have to set it up as an external effect for it to compensate, but it will.
I normally just reamp and line it up later. You have to do it if you are taking a DI and a mic'd signal at the same time, so it isn't that big of a deal.
