P
pearldrum944
I bought a US-428 off of ebay and had problems with it not working. The problems included:
1. Input audio is extremely distorted.
2. No output (including direct monitoring).
3. Trim knobs would not affect the incoming signal.
I have posted on the Tascam forums to try and get it to work, but nothing has helped.
I tried 3 different driver versions, cubase VST, cubase SX, albeton live, audacity, and cool edit pro. The only thing it would do is sync up the controls with cubase and record the distorted audio.
Anyway, I sent it back to the seller and he said that the unit works fine after he tested it again.
But my question is: No matter if the unit is working properly with the computer or not the trim knobs should adjust the incoming signal right? And by turning up the track fader, master, and pushing "Input monitoring" (?) you should be able to direct monitor, yes?
