quick Q on firepod
  • Thread starter Thread starter vollyguy11
V
vollyguy11
On the back of the firepod, are the line outputs stereo or mono and are they a direct out from the input, ie. zero latency and no computer effects, or do they run through the computer before they are output. Thanks so much.
If you are refering to the channel outputs, they are non processed, mono, as if you were using just the firepods for a preamp. The speaker outputs are stereo, and can play back the previously recorded signal, the preamp signal, or a blend of the two.
