Doowah
I'm setting up a home studio in a small spare bedroom in my house. The room in question is on the second floor and has one rather large window that faces a neighbor's house. My house is fairly new construction, and appears to be relatively sound-proofed in general. But I'm worried about that window.
The window is approximately 47" high x 63" long, and it is recessed 3'' from the interior wall. My plan is to sandwich trimmed panels of 2" thick OC 703 or OC 705 between two pieces of sheetrock cut to fit snugly inside the recessed window space, effectively blocking it out. Questions are:
1.) Is this a viable plan? Are there any pitfalls to my proposal, or is there a better way of doing it?
2.) Would the OC 705 work better than the OC 703 for me (i.e., block more sound) because it is denser?
3.) Can I use spray adhesive to attach the rigid insulation to the sheetrock panels without any undesirable consequences?
Keep in mind that whatever I do, the solution must be non-destructive. I want to be able to undo the installation and return the window to its original condition, should I decide to sell the house sometime in the future.
Thanks for your input...
