M
Mike Freze
Hi! I have a question my books don't seem to specify very well.
When you mixdown all your individual tracks in a project to a single, stero file to export, you select the final bit rate, sampling rate, etc.
When you call up your completed songs to master later on (each complete song on a different track in your program), after you are done fine tuning the volume levels, EQs, compression, sequencing, and all that, when you are done mastering your own work, do you need do any bouncing at this stage? Or do you just merely "save" your adjustments to your hard drive with the same file name you gave on your mixed files? Is dithering down from higher bit and sampling rates (for CD production) all done at the mixdown level before retreiving your songs to be mastered? Or should that be done only at the end stage of the mastering?
Thanks for your time. Mike
And personlly, I like to save a file version at the end of just about every major stage of the process. You never know when you'll want or need to go back to them in the future.
