HD recorders, CD-Rs and audio resolution.....
I confess I'm a bit confused by the technical issues surrounding HD recorders and "mix-down" to a redbook audio-CD. Mostly, I'm not sure what CD-R device(s) would be the best to consider for use with a digital HD recorder. What are the features needed to produce a good audio CD? What are the implications of using the HD recorder at higher resolution than cd-audio?
To be more specific, I'm trying out an Akai DPS-16. One of the recommended CD-R drives is a Yamaha CRW8424SXZ. The Akai warns not to record in high resolution for recordings intended for audio CD's because of "troubles" down-converting to cd-audio quality. If I want to record in high resolution is my only mastering option to mix-down to my PC (Echo Mia card) and dither/burn there? If I used a Sony CDRW33 or other higher-end CD-R device with 24-bit AD/DA it wouldn't matter, right? (because the Akai is mastering the CD with SCSI, not audio, so the Sony AD/DA converter isn't used to burn the disk...I think)
I would skip an external CD-R all together except I'm having some PC nightmares and want to be able to record music with the PC out of the loop when I want to just jam (and not deal with Winblows.) Is my best bet then, to get something higher-end like the Sony CDRW and feed it S/PDIF from the Akai DPS-16 (from high-resolution multitrack recordings) to master redbook CDs?
Sorry for the dumb questions (God bless the newbie forum) and thanks for any pointers!
-Shaz
-Shaz
