G
		gene12586
Member
Hi all,
I have some very beginner questions about setting up my home studio signal chain with some equipment I have access to. Sorry in advance for the lengthy message. Here's the equipment:
Audio interface: Motu896mk3
Computer: 2020 27 inch Imac w/ 3.3 ghz, 6 core processor (w/ garageband)
Mics: Sure sm7b, Sure sm58, Sure sm57, two Rhode condenser mics
Monitors: Adam A7x monitors
Headphones
Mixer: Yamaha stagepas 600i
For a project I'm working on, I want to first be able to record myself playing my acoustic-electric guitar while singing at the same time, and I want some reverb on the vocals. Then I want to overdub with a doumbek (middle eastern hand percussion instrument). Then after I record that, I want to overdub with an electric guitar. I should also mention that I currently have no sound treatment on my walls, but I plan to be getting some in a few months. So several questions:
1) I've heard that direct monitoring is preferred to input monitoring to avoid lag... but as I said I also want reverb when I record the vocals while I'm playing acoustic. So it seems to me then that a logical thing to do then is to have a signal chain as such: Guitar and vocals microphone plugged into mixer, then mixer plugged into audio interface, then one line going from interface to monitors (or headphones) and another line going to computer. Is this doable? The issue is that whenever I watch videos of people recording acoustic guitar and vocals, I usually see that the acoustic is miced and both the acoustic mic and the vocals mic feed into an interface, then interface goes to computer where effects are applied (in this case, reverb), then computer back to interface, and then interface to monitors/headphones. But isn't this the input monitoring approach? So there would be lag, and wouldn't that interfere with the recording? Overall, what are the pros and cons of using the direct monitoring setup I proposed vs. the input monitoring setup? Which would work better in terms of quality and so on? Also, I tend to not be a huge fan of reverb applied using computer software; I like the sound of the reverb on the mixer better... so this would seem to be another reason that the direct monitoring option I presented above might be better.
2) For the two options I listed above, when I'm just recording the acoustic guitar and vocals, would it be better to monitor through the monitors or through headphones? I realize sound quality will obviously be better through the monitors.... My logic tells me that for the direct monitoring approach, I can get away with monitoring using the monitors (instead of headphones)because there will be no lag. Is that right? But what about for the input monitoring approach? Wouldn't using monitors instead of headphones screw up the recording because of the lag? So would I use headphones for the input monitoring approach?
3) When I overdub the doumbek, I'll mic the doumbek and feed it into the interface, and then the interface will either send out to the monitors/headphones (in the case of direct monitoring approach) or will go to computer and then back to interface and then out to monitors/headphones (in the input monitoring approach). But at the same time since I'm overdubbing over the pre-recorded acoustic/vocals track, I'll also have the pre-recorded track feeding from the computer to the interface and then to the monitors/headphones. Regardless or whether I go the direct or input monitoring approach, will having sound coming from two different sources be a problem? In other words, on the one hand sound will come from the computer for the pre-recorded stuff, and on the other hand the sound from the doumbek will come from the doumbek... so will the two sound sources be combined smoothly into one in the interface and then sent out together to monitors/headphones? Or am I missing something here?
4) As mentioned, I'm planning to then overdub with electric guitar (I plan to plug the electric guitar into my guitar amplifier, mic the amplifier, and then run the mic into the interface. What I'm confused about is how it's possible for one to overdub with an electric guitar in this fashion. I'll have the prerecorded track of the acoustic guitar and vocals coming from the computer to the interface and then out of the monitors (or headphones), but then I'll also have the electric guitar sound live coming out of the amplifier and this will be routed to the interface, which would then potentially go to the monitors/headphones as well as to the computer (but then I would have the electric guitar sound coming out of two different sources, both the guitar amp and the monitors/headphones, which I imagine won't work). So is the idea that I need to somehow make it so that the amplifier to interface sound doesn't then go to the monitors/headphones and instead only goes to the computer? Is that the way to do it? Is that possible? Or is there some other way that's typical to do this? Also, for doing this, is it preferable to monitor through the monitors or headphones? If headphones are the better way to go, how would this even be possible if the sound from the electric guitar isn't being fed into the headphones? (in other words, I wouldn't be able to hear the electric guitar sound because I have headphones on, and the only sound coming from the headphones is the pre-recorded computer track)
5) In comparison to the direct monitoring approach I listed in question 1 above, I thought of another way to do the signal chain with direct monitoring, and I'm wondering if this would be better: acoustic guitar and microphone for vocals both fed into the mixer, then the mixer feeds out to the speakers that came with the mixer, then I mic the mixer speakers, then feed the mic to the interface, then the interface goes to the monitors/headphones and also to the computer. Would this be a better approach than the other direct monitoring approach I mentioned in question 1 above? Or no? I don't have any compelling reason for thinking it would be better or worse; I just thought I'd ask out of curiosity.
Any help anyone can give would be so very much appreciated.
Thanks,
Gene
Headphones
Thanks,
Gene
