Here's a link for an excellent article on eq>>> http://www.homerecordingconnection.com/news.php?action=view_story&id=154
But... I have ONE question. I just do not understand what is meant by this phrase (you can read it under the head Cutting the notch.
Select a band that is near the range you wish to notch out. Pull the gain for that band down 3 - 4 db. Set the Q or bandwidth to be around 1 octave. Different EQs use different values for this, but basically, you only want the Q about as wide as the range you wish to notch out. Then you just sweep the frequency of the band around the range you're looking to notch out until you hear that you've hit the pocket.
I have a vague idea, but don't see the difference between band and range.
What I know about Q (same as bandwidth?????), is that the higher the number, the smaller the notch. But what is meant by "set it around 1 octave??"
