M
Meb
Alan,
I recently purchased a VTB-1 preamp and even more recently bought your C1 microphone. Let me first say, that I'm extremely happy with the sound quality of both. I am planning on posting a little more of my opinion about the C1 in comparison to other microphones I've tried on my voice sometime soon. But, first I have a question about the VTB-1.
I seem to have to crank the output level almost to it's maximum in order to get the volume I want into Cubase SX. Is this normal? I'm using 1/4 inch balanced Monster Cable to go from the 1/4 inch outputs on the VTB-1 to my Layla 20 soundcard. I have the Layla's Input levels set to +4 dBu. I have the impedance on the VTB-1 set to 200 and am not using the Tube Blend section. I usually end up setting the input to about 40 or so, but then in order to get a hot signal into Layla and into Cubase, I usually need to crank the Output of the VTB-1 almost to it's max to get close to 0 db. These are not screaming songs mind you, that I'm recording, they're probably medium loud, but is this normal?
I 'd appreciate any information you can give.
Thanks,
Meb
Thanks,
Meb
