steakmusic
I've been checking out Brian Lee White and Bobby Owsinki's tutorials on Lynda.com, which are really comprehensive and clear, but I'm a little perplexed by Bobby Owsinki's compression technique.
He seems to employ what I think is referred to as the "safecracking" method of setting compression parameters. His method is to start with the longest attack setting possible, the shortest release setting possible, and then dial the two parameters in from there.
What confuses me is that when he talks about using a compressor on a snare track to "help even out the dynamics of the snare hits," he uses an attack of 125 ms and a release of 294 ms. If you're trying to control the dynamics of a snare track, which contains transient material of varying intensity, then it seems logical to me that you would want quite a fast attack time, in the neighborhood of perhaps 10-20 ms or less. With an attack time of 125 ms, I would think that the transient portion of the waveform has already long since passed by the time the compressor starts reducing gain.
So my question is: if you're trying to even out transients, why would you use a long attack time on your compressor? If anything, I think you'd just be clamping down on the "sustain" portion of the snare hits, making them even quieter relative to the onset of the snare hits.
Obviously Bobby Owsinski is a total pro, and he has at least 100,000 hours more experience than I do in the realm of mixing (I'm just a peon who started learning this stuff several years ago), but I just want to try to understand the logic behind this compression technique that he's detailing.
Thanks!
Thanks!
