nate_dennis
So this is actually related to an old Hammond L103 I scored for cheap, but the circuit ideas should be the same as guitar amps . . . .so heres the question....or rather questions.
When I fire her up, not all of the tubes glow. Is it normal for tubes to not glow or does that indicate a problem? If it is a problem (as I suspect it is) how I determine if the problem is a connection or a bad tube? Thank you so much for the help guys. Someday, maybe, I'll be able to help you all out.
-Nate
-Nate
