You can use a matching transformer to match the low impedance microphone to the hi impedance (unbalanced) input on the C-Port, but the unbalanced inputs probably wont have enough gain to make them useful for recording mics. Try it and see. You should be able to get the "in-line" type of transformer for $20 or so.
For the best sound quality, you would want to purchase a separate mic pre-amp, and connect its out put to the unbalanced inputs of the C-Port. Or if you have a mixer with built-in mic-pre's, run your mic through that, then into the C-Port.
Twist
