I got
a DPS16 last September and since then I have logged many hours and nearly filled the 10 gig hard drive. I have a Yamaha CD burner, model CRW8424SX connected via a SCSI cable and it works great. The DPS operating system contains all the software you need, and the user interface is built into the DPS16. No sweat.
Basically, there are two routines in Project Mode:
1. Backup which backs up a song (or project) as it exists in the DPS16. The backup contains all tracks (including virtual ones) effect and level settings, etc. etc. You can delete the project from the hard drive and then reload it (another built in function) later and totally redo tracks, remix, whatever.
2. You can write two of your tracks to a CD, one song at a time. What you do is mix your tunes down to two tracks, and there's your stereo mix, ready to write to CD. Once you have written all of the tracks you want, the DPS16 allows you to perform a 'Finish' routine. The CD can now be played on any CD player. Easy peasey
One thing to watch when writing your two track songs, do not use the 'max' write speed setting. It will frequently cause the write function to crash, and this track will be wasted on the CD. Set the speed parameter to 2x or 4x or whatever your burner can handle. I found this out the hard way but Akai's technical people straightened me out and it's been clear sailing ever since.
Everyone is welcome to give a listen on
http://www.MP3.com/theloniousmonkey Suggestions and critiques are most welcome.
Cheers
