Speedy VonTrapp
I've been doing a ton of reading since first coming to this site, and I've got a pretty good handle on the way that I'm going to be doing things, at least to start with. I still have an issue that I can't seem to work out that well yet, so I thought I'd ask about it here.
I know I've posted my crappy setup before, but I'll do it again here for this thread. (At least the relevant parts.)
I have an SM58, and a Peavey Diamond 22 V Series mic to record with. (Lack of budget leaves me with no other mics for now, I accept that, and will just work with what I've got.)
I have no pre-amp for the mic. I have a portable PA, but other than that, no way to really mic a speaker for the vocals.
I also have a Digitech Vocal 300 pedal, which I love. I found out the hard way about using it for recording, though. My settings that sounded great live, make me sound like I'm in a tin can when I recorded vocals before.
I use a Yamaha MD4S, then route that into Pro Audio 9.
My question is this: Most of what I've read seems to suggest that putting compression on the track as it's being tracked is a good thing. The only way that I can achieve this is by using the vocal pedal that I have. Should I do this, and set it so that there are no effects, EXCEPT for the compression? And, will running through the PA be a "better than nothing" setup for micing a speaker for the track, or is going direct better?
I realize that there are MUCH better methods overall, but considering my equipment, and lack of ability to upgrade right now, I'm going to do it using what I have, and do the best that I can with it.
Any suggestions are very appreciated!
Thanks!
-Speedy
Thanks!
-Speedy
