Question about recording softwares?? Help..
  • Thread starter Thread starter PrettyChica
P
PrettyChica
Ok, I've been using the MR-8 digital recorder for like almost 2 years but the recorder got damaged. So now I'm thinking about recording my stuff using the computer, with a recording computer software. Any of ya'll know any VERY user-friendly recording softwares out there? I prefer an 8-tracker. Also, I have the MXL 990 mic, will I be able to connect that to the computer? if so, how?
I am assuming that you will want cheap as well as user friendly. You could try N-track which the last time I looked was $35 shareware and works wonderfully.
Most of the musicians I know who are not engineers really like Sonar, a lot. Most of the engineers I know who are also musicians, like Cubase SX.
As fars as getting your mic to go into the computer, there are a ton of sound cards out there that can do the job and even have built-in phantom powered mic preamps. It depends largely on your budget which one you want to get. There is a ton of used stuff on the for sale forum if you need to get in on the cheap.
A lot of people like the inexpensive M-Audio USB-2 interfaces. I like Presonus.
Good luck!
First of all you need a mixer to connect all your mics and instruments into, then you take the output of the mixer and connect it into a soundcard (audio interface) which transfers your audio into the computer and then you can record and edit the sound in the computer using a software. so for now these are the three things you need
mixer, audio interface and a software.
My recommendations are
any m-audio soundcard and some cakewalk software in your budget.
Not if the audio interface has a phantom powered preamp you don't. Whatever you get MAKE SURE it has phantom power, the MXL990 is a condenser mic and like all condensers require phantom power.
connect the mic to a sound card? I wouldn't wanna open the pc and touch any of the parts in there.
When people say "soundcard" they are usually refering to a audio interface. There are some (PCI) that need to be installed directly into your PC, but most connect via USB or firewire. If you get one of the firewire/usb ones, you won't have to open up your PC at all. The interface pretty much replaces your stock PC soundcard with something specifically designed to record music (better preamps, A/D converters, etc).
Also, people don't take kindly to cross-posting in BBSs. Find yer forum, and post it there ONCE.
Justa little friendly advice :)
Ok then I will get the soundcard that I can connect via USB. If I connect this soundcard to my pc, it wouldn't damage the soundcard that is inside my pc would it?
With the MR-8 recorder, I was able to copy/paste tracks which meant I didn't have to redo the same hook over again. Will I be able to do the same with N-track?
No, it'll be completely separate. You can have windows still use your old soundcard for all your non-recording stuff still, and only use the audio interface for recording.
