I
		Ironklad Audio
wow...this one's still going??
			Thank you! It is sure lonely when no one understand what one is talking about. Knowing that even one person come around is gratifying.
I have no idea, to be honest. When you talk about "integrating the wave", you are at the edge of my understanding of mathematics terminology.
I have just stuck to a simple mental picture all along. A phase inversion is nothing more than a phase change of a specific value that happens instantaneously (t=0). It is no different than any other phase change in that the phase rotates around the rest voltage; i.e. the rest voltage is not affected. This means that phase inversion only has the equivalent result of polarity inversion in one special circumstance, when the rest voltage is 0.
Then I add the idea that phase change is not limited to a value of 180°. If one wanted to, they could change the phase by any damn degree they wished. There is nothing special about 180° in that regard. It's just another number. And regardless of degree value, the same formula should be used for all of them. One should just need to plug the value into the equation and away you go.
Changing the sign, OTOH (a.k.a. multiplying the terms by -1) - which is basically all a polarity inversion is, is an artificial manipulation that has nothing to do with any phase change methodology. The fact that a polarity shift resembles a 180° phase change in some (but not all) aspects is nothing more than a happy coincidence that does nothing to actually make phase and polarity the same thing.
			Nope. One of the resulting effects of a polarity inversion is a 180° phase inversion, but if the rest voltage is not 0, there is also a change in the rest voltage value and in the sinage of the wave values. With a phase change only, those extra changes will *never* occur.I think you meant polarity inversion is nothing more than a phase change of a specific value that happens instantaneously.
Sorry, I wan't necessarily referring to your equations when I said t=0. I probably shouldn't have used that equality; I would have avoided that confusion. All I was trying to say is that it was an inversion and not a shift; i.e. that it takes place IN zero time, not AT zero on the timelineHumm... I don't think it is only at point t=0. It can happen at any point of t. It is just that there is no phase shift (same as time delay/shift). It just happen instantaneously.
I never really wrapped my head around the calculus; my calc class in college was obscenely early in the morning and I kept nodding offHowever, I still want to go far away to some mountain and re-contemplate this matter over again... Perhaps Maxwell equations would help?
			Meh, imaginary numbers on a two dimentional cartesian system are OK. I'll start getting concerned once you guys start discussing phase vs. polarity ramifications from electrons point of view, like whether the issue would be different if they had a different spin, and whether you can truly believe that there is no DC offset in all 31 dimentions.Wait till we start resorting to imaginary numbers!!
			Or whether polarity and phase have no definition until we obesrve them? Or is it that you can't know both polarity and phase precisely at the same time? Or maybe that polarity and phase only appear to be equal undercertain conditions because we are in a universe conducive to human beings who can ovesrve them, but in the universe mext door, polarity more like the color blue and phase is more like the taste of stale coffee, and the closest thing to a human being is Michael Jackson.Meh, imaginary numbers on a two dimentional cartesian system are OK. I'll start getting concerned once you guys start discussing phase vs. polarity ramifications from electrons point of view, like whether the issue would be different if they had a different spin, and whether you can truly believe that there is no DC offset in all 31 dimentions.
Except that, all mathematical theory aside, that is what the "Phase Reverse (or invert)" button of all commonly used audio equipment actually does.telling them that all that button does is invert phase will give them the wrong picture, the wrong impression and the wrong idea of what is actually going on because that is NOT what the button is doing.
			Feed an analog synth signal that purposely has a nonzero DC component in it .....
Remix or remaster recordings that someone else made that has one or more non zero DC components in it becaue the rookie who did the original work used crap soundcars and never even heard of offset, and tell us that flipping the polarity is only flipping the phase.
It is flipping the phase in the monitored signal only. The recorded signal is unaffected. There is no "delaying" going on in EITHER signal.My Firestudio and Digimax don't have any phase reversal switches (which kind of upsets me). I'd like to test phase on all of my channels, so my question is this:
In Cubase, in the mixer window, there's an option to flip phase on each channel. If I flip phase in monitoring mode, will it record with an inverted phase, or is it just phase delaying it? Thanks in advance
-Joel
Exactly why there is so much loony misinformation, myth, and "expert opinion" in audio acoustics.Quote:
I was referring to calculus...
Feed an analog synth signal that purposely has a nonzero DC component in it (yes, analog sound sculpters can and often do want that) and tell us the flipping the polaity is only flipping the phase.
This thread is a waste of time.
G.
			"Thread's dead, baby. Thread's dead."Die, thread DIE!!!!
