spantini
COO of me, inc.
What say you..
Scenario : Musician-A has DAW-A and wants to collaborate with Musician-B who uses DAW-B (different DAWs)
Musician-A doesn't want this to be a professional project (yet), just to send Musician-B a rough mix of a couple of tracks so he can add another part, then send a rough mix of that back to Musician-A and repeat until all parts are there.. all as .wav files.
Musician-B sez there's no way this will work, there are problems with track alignment and other stuff. Sending .wav files back and forth is not acceptable - won't work.
Musician-A doesn't see what the problem is. He's manually aligning all kinds of stuff in DAW-A.. why can't DAW-B's .wav files just be dragged into DAW-A and manually aligned?
Musician-A knows there are other, larger difficulties with compatibility, but for just creating parts and assembling them into a song to get the ball rolling those shouldn't impede the project at this point - right? Now, to proceed on to a more professional level, Musician-A realizes they should both use the same DAW to continue. But that's a ways off.
