pt8 was working fine.. then!
  • Thread starter Thread starter shanemccarthy
shanemccarthy
this noise comes on and off frequently anytime a track is record enabled. Its defo not the mic or lead.
the noise:
www.box.net/shared/z3ddtbj7hs
pro tools configuration:
www.box.net/shared/os456k50kd
My Set up:
Computer: dell studio 1735 laptop (latest laptop they have)
O.S: Vista home premium SP1
Processor: Intel(R)Core(TM)2 Duo CPU T8100 @ 2.10GHZ 2.10GHZ
Ram: 4.00GB
System Type: 32-Bit O.S
Audio Interface: M-audio fast track pro
Software : M-Powered pro tools 8
i started using a midi keyboard for recording round about the time it started happenin if that could be an issue. Any help would be greatly appresiated, i'm lined up to record for a band this weekend.
Thanks
Shane
Turn off "Ignore Errors during Playback/Record"
See if any error messages come up.
Is it possible you have some dodgy routing set up?
Does it do it on all sessions?
What is the signal path prior to the interface?
Sounds like radio freguency interference or crosstalk from poorly shielded cables or improper grounding. Check that midi and audio cables are not crossing over an electical cord. You may also need to lower the gain of the imput signal a bit. Hope this helps.
thanks for the suggestions,
the routing setup:
http://www.box.net/shared/rkmbdlyk2d
Ya it happens on all sessions, old and new.
its just a mic (akg c2000b) + lead straight into the interface, i've tried different mics (dynamic/condenser) and different leads, phantom power on/off all to no avail.
ya i agree it sounds like some interference so i moved the everything to another room and set it up seperating all the wires so they didn't cross. but i'm still scratching my head!
