D
dintymoore
Guest
This is a continuation of this thread:
https://homerecording.com/bbs/showthread.php?t=294802
I put this 8 in 2 out out passive sum box together, what makes it a prototype is a) I imagine it will be tweaked a lot and b) in order to get it done, I used stuff on hand, from Radio Shack and I didn't want to be concerned about cosmetics. It's butt-ugly!!!
The box was a God-awful ADC graphic eq (puke-barf-hurl) and it's in terrible shape. I put some foil tape on the front. Actually, painted and with a new aluminum front it could be ok. I like the size.
The back is brutal:
All the guts parts came from R.S., I know the resistors are crap. The pots aren't too horrible and the jacks are so-so. Everything there is airport - candy priced.
It got pretty busy real fast. I would make it differently if I was to do it again.
Eventually I'd like to make it, my tube amp, my speaker selector and my passive volume box all into one console, and that's when I'd buy some koa.
It's begging for something in that space on the right on the front... maybe a '63 VW speedometer or something...
Here's the schematic, I call it iGor2000:
here's how it's set up:
ch 1 and 2 come from my Summit tube eq and those are my important lead vox and lead solo channels
ch 3 and 4 are separate channels for stuff like bass or another mono track. I put kill switches (S1 & S2) on the reverb sends on those channels
ch 5 and 6 are a stereo pair and the panning is set on the computer. This is where most all the tracks are
ch 7 and 8 are from my Roland SC-8850, which is the synth module I use for pretty much everything.
It's got a stereo effects send and receive so that I can use my SPX1000, which is the best reverb I have at the moment. It's a dinosaur but a good one. I imagine I will replace it sometime.
What I do is put the output into ch 7&8 of my Delta 1010LT card and that's re-routed to the SPDIF out which goes into my T.C. Finalizer (that gets you 24 bit as my Finalizer is only 20bit but 24bit if you use digital in). Then the Finalizer outputs it into the Delta 1010LT's SPDIF in and that's what I record as my final LR stereo mix. It's sort of based on the system I grew into with my Otari MX5050 8 track reel to reel.
I know it's odd having 100KΩ pots, but that's all the ganged ones they had at R.S. and I wanted it to be done with one pot.
I used the 10KΩ pots for pan. It doesn't allow full panning but for what I use those channels for it's fine. I would think that higher values would make the panning wider. Now it's just the middle 25˚.
I didn't attach one contact of each effects send pot to anything. Those are the 100KΩ pots. Does that matter?
Should I be using resistors in some other places, like between some of the bus bars?
The back is brutal:
