M
magnetic
When I start Protools up all goes well untill it comes to SDS applications/utilities or somesuch. Sorry forgotten exact term. The green percentage downloaded box reads about 75% when it stops ; the result is the PC is frozen. I have no mouse mobility,cant turn the PC off,nothing ! The only way I can unstick the PC is to pull out the mains plug.
As well as that symptom,when starting Protools it goes through the start up ok,then the screen goes black and the PC restarts itself over and over again. When I first started using Protools I had the first problem a few times,but after re booting the PC the DAW started ok. I havnt used Protools for a month. Last time I used it,it was working ok.
I,ve tried re installing LE 7 and tried starting up in safe mode,unfortunatly in safe mode,the interface isnt found. Andy.
