Proposed DAW for Sonar 4
  • Thread starter Thread starter Relakst
R
Relakst
Before I go ahead and order this I thought I would run it by people who are in the know.
PREMIUM TWR BLUE WAVEMASTER CASE
OCZ MODSTREAM 520W, 120MM FAN MODLAR CBL POWER SUPPLY
SKT 939 ATHLON 3500+ 64 BIT 2.2ghz
ASUS A8N-E SOCKET 939 PCI-EXPRESS MOBO
PC3200 512MB PREMIUM BRAND RAM x 2
IDE80GB 7200 rpm HDD 8MB CACHE x 2
CDRW 52x32x52 WHITE
64MB GEFORCE 6200TC PCI EXPRESS VIDEO CARD
2+1PORT IEEE1394 FIREWIRE PCI ADAPTER
19' MONITOR
LOGITECH CORDLESS RECHARGEABLE KEYBOARD AND MOUSE
MOTU 828 MK2 or RME FIREFACE 800 INTERFACE
Wha'd yer think? Any suggestions?
Get a bigger hd for audio. No motu on pc...RME all the way. Add a dvd-rom as well for about $25, or burner for about $75. Backing up to DVD will make you much happier than cd's...I have some DVD-RW's and they make my life very easy when it comes to backing up. Make sure you get a premium firewire card since that will be the interface to the computer for the Fireface.
Check out used Sun GDM-5410 21" monitors on ebay...you can probably get 2 for about $300. They are top of the line Sony Trinitrons branded by Sun Microsystems that retailed for over $1000 about 3 years ago...I use two myself...they run 1280*1024 at 100hz refresh, and look fantastic.
Go with the 90nm version of the 3500+ since they run significantly cooler than the 1.3um versions. I believe they are know as the "Venice" core.
Also for a cheap interface check out a Digidesign R1 from the old "Session 8" system, you should be able to find one pretty cheap, and works great as a generic controller on Sonar.
Is that video card fanless? If not consider looking for one that is, and definetly one that is dual-headed.
Good luck!
Jake Lampe
CDRW 52x32x52 WHITE
19' MONITOR
