Program Change
  • Thread starter Thread starter sikter
sikter
sikter
I want to export my very first MIDI file.
I’ve been using midi for a year but I was exporting audio only.
To get midi file done I know that I need program all tracks to keep their “patches”.
I open Part in the first track in Key editor and choose Program Change in position 1.01.001.
Then, I open List editor and see that Program Change is on the top of the list.
I repeat this for all tracks.
Now I need to feed my Program Change with the correct digits for
Data1 and Data2 (Probably something else as well)
How can I find those numbers?
Example: Data1=128 and Data2=1 gives sound of Shot Gun when midi exported.
VST instruments used in project are Hypersonic, Edirol Orchestral, Battery and Real Guitar.
everything will need to conform to GM channel assignments for it to play on any midi system so unless you are using plugins that conform to that as far as patches, you will not be able to get the midi file to work with anything but your cubase file
Thank you for respond,
I made it work. GM channels assigned. I found those numbers hard way but that's the way I do everything.
