Prof studio advise
  • Thread starter Thread starter amt7565
I think you need to give us more information before we can give you more specific answers.
•How many songs?
•How many tracks per song, and what is the typical track layout (how many drum tracks, how many other instruments, how many vocals, back up vocals, etc.)
•Are your instruments "real" or samples?
•Are there drum tracks at all? (You didn't mention them)
•How long is the average song?
•How much fixing/editing do you anticipate (cutting and pasting between takes, tuning vocals, editing the song forms, etc.)
•You are retracking the bass? How good of a bass player are you? Can you do each song in one take? One take plus a couple of punch-ins? Multiple takes and comp the results?
•Are there multiple lead vocal tracks that need to be comped?
•How "clean" are the tracks? Will a lot of time have to spent setting up noise reduction or editing out pops, clicks, mouth noises, coughs, grunts, etc.?
•Are you going for a purely natural sound, or will you be using a lot of mixing special effects (delays, autopanning, changing ambiences, etc.)
Typically in pop music, when you have 24-48 tracks, a quality "pro" mix would take at least 4-6 hours per song for mixing. This is NOT including major editing or retracking or other major surgery.
Even in a budget situation, unless your raw tracks already sound fantastic, figure at least 4 hours for the first song, and then if all the other songs were tracked with the same instrumentation and mic positions MAYBE you can mix the rest in 2 hours each using the same basic mix settings as the first song.
I'm not sure if this advice qualifies as "negative", as I would say the same thing to you (or any potential client) if you asked the question without telling me about your 45 minutes per song estimate. I haven't heard your music - if the songs are incredibly well recorded, not many tracks per song, and really short in length - then maybe the 45 minutes is "possible". I don't think I've ever managed to mix a song that fast, unless it was just a solo or duo recording, or else vocals added to a premixed sequence. But maybe they are incredibly skilled mixers. In may case, I would categorize 45 minutes as qualifying for a rough mix, not a final one.
The best way to find out some of these answers is to ask for a client list. Then call some of them and see how long their mixes took and how happy they were with the results - especially if you can find a previous client with a project similar to yours.
Please let us know how you like the ultimate results of this studio's work. I think a lot of us are really curious by now!
And the main reason you want to use a different studio for mastering is two-fold:
•A mastering studio supplies the engineering skills, hardware and software, and acoustic space that is optimal for mastering. A typical mixing studio does not. It's kind of like why you might prefer to get your transmission done at a transmission specialist, and not a car wash.
•One of the main goals in the mastering process is to fine-tune the mix as provided by the mix engineer created in the mixing room. If you assume that the mix engineer has already done the best possible job he/she can with their ears on their equipment listening on their speakers in their space... than it would besomewhat redundant to have them relisten to it again and master it. BUT... if you take the mix to fresh highly trained ears with better mastering equipment on better speakers in a better space... then you are actually accomplishing something constructive.
Is that more understandable?
OK excellent! Thank you for the suggestions on Mastering.
Here is what I got:
*My music is instrumental music. No vocals.
*Total of 8 songs, each averaging 4 to 5 mts.
*Each song has 8 to 15 tracks. Now most of these tracks are in MIDI format. The Guitars(wave) make up from 2 to 4 tracks on average per song.
*Some tracks, I have played Piano(wave). This is on 2 or 3 songs and is similar to the gutiar tracks recorded in stereo.
*so the average song has guitar/piano in wave format and the rest in MIDI.
*I have also played Bass. I am not actually a bassist, But I can play ok and I am hoping a compressor will balance my weekness. That's why I like to play the bass at the studio.
*As for sound quality, it's not the best. I certainly would like some clean up. But not too much time on this since MIDI has most of the instruments and should provide clean sounds. So the guitar tracks is all that will need tweeking and cleaning. Some grunts I have managed to tweek down by volume changes.
*As for special effects I dont have any plans for it. I already got the effects I need in my tracks.
*I have one drum track only. This is also from MIDI.
*I dont anticipate any editing as I would have already edited everything on my PC. Unless some tracks really need some editing at the studio.
Questions:
When I route my guitar tracks through my sound cards to their system what is the best the studio can do? Howmuch will it be degraded when compared to playing live?
Once mixing is done, how would i carry the final mix to anotehr studio for mastering? what format? And how much can i expect to pay for mastering, hourly rate?
Thanks again for having taken the time to write in detail. Any other adivse and suggestions will be greatly appreicated. I will try to get a client list and talk to them. :D
Given that almost all of your tracks are midi, let me make another suggestion:
Why don't you take a shot at mixing this yourself?
In my opinion...
That studio looks pretty nice for $60 an hour! However, I am not sure it is the best studio for you. I would first be looking for a studio that can work directly with SONAR. If you can "bun" your tracks and take them in to be mixed on a console directly from SONAR you could save yourself a lot of time and trouble.
Regardless, for that price I would strongly consider giving them a crack at one song to start. Test the waters. See how you get along with the engineer. If you don't like it, keep looking. But with gear like they have, at that price, I would guess they are trying to build a client base, which could be good for you.
I am guilty of 'mastering' songs in 35-45 minutes. ( I am not proud of this.) But I gotta make a living and as a whole musicians around here are on a tight budget. Many musicians do not appreciate, anticipate, or have the slightest idea where to go for mastering. I do it myself because I have to. When I say "at least half an hour per song" I am of course hoping I'll have more time than that... but with the equipment I'm using I can do a 90% as good as possible job in that time... it's the "polish" that takes the most time and money.
I've always found MIDI projects to be easier to mix than most. Frankly, without vocals or live drums, your project seems like it could be done well without spending a fortune.
I am familiar with SONAR and would not recommend doing it all your self unless you are very patient. If this studio can use MIDI to carefully record all of your tracks seperately they should be able to make it sound better than from within only SONAR.
I'm sure many members of this forum have done a great job mastering material with less equipment then they have. I think they have a lot of equipment for the money... do they really know how to use it is the question.
Thanks Guys.
Last year I tried burning my tracks in. bun format and took it to a studio. The studio was not the best. It was run be a very young fella. Anyway when I loaded the tracks on their system, the timing was off. Apparently the computer clocl speeds differed from mine to theirs and things were screwed up. It was not synced. It took 8 hours to mix 7 songs and it turned out crappy. I came back home and discarded the master CD and mixed down everything bymyself. And it turned out terrible too! That was the story of my first CD.
When I spoke to the current studio person, he immediately suggested I bring the equipment instead of the tracks on a CD. He said "from experience, he knows that it's best to do it this way". So I am certain he is aware of syncing problems.
As for mixing bymyself, that's a NO NO. I have been working on this project for 8 months and I fail to be objective about it. It certainly needs fresh ears.
Midi or not, 8 hours to mix 7 songs is bloody impossible in order to obtain a quality mix.... it's no wonder it didn't turn out.........!
And from what you describe on this project, you're setting yourself up with the same unrealistic time expectations... PLUS you want to track bass live to it?!?!?
Seriously...
The thing for you would be for you to only do a single song at the studio, so that you can get a REAL time estimate for the time it will actually take.... plus you can also hear the end result before committing the rest of your songs to the process....
Once you really know how much time is involved, you can adjust your budget (or your expectations) accordingly....!
Bear I agree 8 hours was too little for that 1st CD, since most of the time was spent fixing sync problems both in MIDI and audio.
I have to finish this within 2hrs/track. That's all I can afford now. So that will bring me to about 8-16 hrs.
Hopefully when I get rich and famous later on I can spend an entire week or weeks mixing and mastering another CD. And I look forward to that!.
Or look for a studio with better rates. That place is priced pretty high for the gear they have. $65 an hour around here gets you the best studio in town during the off peak hours. Try negotiating a better deal on a block of a time.
Texasroad, how much should I expect to pay for that studio?
Thanks
The reason you want to record the bass in the studio is a bit beyond me.
Bass is one of the easiest instruments to record yourself. One bass, one pre-amp + DI and basically you're ready to go.
If you want them to use their compressors to fix your basstracks, you can give them a pre-recorded track just as well.
Thanks
If that was here in Phoenix it would probably be a $35-45/hour place.
Every locale has it's own going rate, and it is fruitless to compare one part of the country to another. I have plenty of friends in Manhattan who have an ADAT and a Mackie and are charging twice what i do per hour, because they can given the local market.
Meanwhile in my area the local mag's are filled with $25/hr special offers, so it's kind of hard for me to realistically charge 3 or 4 times that much, even given the fact that i offer much more.
Seems like studios are so many around. Looks like not a big money making industry unless you have expenisve equipment to support top clients.....
I think I am going to negotiate with this guy for $40 or $45.00/hr so that I can maybe use the studio for 2 days instead.
Thanks for your support :)
