B
bryanzera
I'm trying to mic my acoustic guitar. I get everything set up. Cables routed, everything in place, etc. I snap in front of the microphone (DON'T TAP ON THE MICROPHONE! IT MIGHT HURT THE DIAPRAHGM!) to see if I'm getting any signal.
Nada.
The mic I'm using is an ECM8000, which requires phantom power. I check to see that my mixer has phantom power turned on, and it does. I try a different channel with no different results. I jiggle the cord at the mixer and I get a signal. As soon as I drop the cord, I lose the signal. I replaced the ECM8000 with an SM58 to test it, and without jiggling the cord, I get a signal.
Now, I'm pretty sure that phantom powered mics actually have power pumped thru the ground channel, whereas dynamic mics just use the ground for ... well, grounding.
Could it be that my ground connections on the mixer are faulty, or does it look like the cord is the problem?
Nada.
