altruistica
Member
Hi Guys,
In order to save the wear and tear on the MRL tape I bought for the MS-16, I decided to record the entire tape (only 4mins.....short version test tape) to the hard disk recorder (MX2424) then to record it onto some NOS Quantegy 406, using the 8" reels that JP kindly let me have
I'd already setup the MS-16 using the tape this week and things seemed to be overall within spec.
I used the MX2424 to edit the material to give me a test tape with 4 minute tones (1k, 10k, 16k, 100Hz) of each, making the final tape around 16 mins long. At the same time as dubbing this to the new tape, I was in and out to the other room sorting out a RAID enclosure I've bought to use for long term storage of the MX2424 material.
The signal from the MX2424 was being sent via the mixer to the MS-16 with levels at 0VU and everything seemed to be going fine.
As the tape neared the end (during a final 1K tone I'd edited on the end) something must have happened, because when i returned to the room, I noticed there was no signal on any of the MS16's meters. I stopped the tape and rewound to the beginning but on playing it back, nothing.
I dug out the manual and suspected something must have fused. I took the cover plate off and found that both of the T3.15A fuses for the 'Regulated +/-15V Rec/Rep Amp' (F3,F4) had blown.
I took replacement fuses out of my other MS-16 (as I couldn't find any T3.15 fuses in my spares......duly ordered), but these have blown as well. Hmmmm........something more serious then.
This is the first time since getting the machine (would you believe now, a year ago) that I've actually been running the system at what I guess is full whack (ie. 16 tracks recording at 0VU for 16 minutes). Would I be right in thinking I've blown something that supplies power to all the cards? I'm presuming that's what the 'Regulated +/-15V Rec/Rep Amp' (the clue being in the name of the fuse).
Have any other MS16 owners or technicians ever had this problem and more importantly what was the fix?
Thanks for any help you might offer.........time to dig into the manual methinks.
Later,
Al
Later,
Al
