Keg,
I see that you've scored a 424mkIII, so congrats. As I said before, I have one, and I think it's a great machine.
As you have now discovered, the 'buss' on the 424mkIII is basically a 2-buss/stereo L-R type buss. All 8 inputs on the main mixer get mixed down to either left, right, or somewhere in between.
As per Dr Grip, and the manual, the tape tracks 1 & 3 record off of the Left side of the stereo buss, and tape tracks 2 & 4 record off the Right side. That's basically inherent in the design, and it's why you got the recording you got, as described.
The answer you're looking for, I think, is a way to record 4 tape tracks with 4 separate inputs, simultaneously. The way to do this, is to switch the REC FUNCTION to DIRECT, on each track, 1-4.
When in DIRECT mode, each track will record only what it's direct channel input is. Track 1 records input 1, track 2 records input 2, etc, directly.
The BUSS vs DIRECT recording methods are all described in the Tascam manual, and the manual is not too bad, if you read it.
Good luck, and again, congrats. I think the 424mkIII is a great machine, and I'm happy for you.
