Seems to me you’re not getting sync after the PPS-1 or your DAW receives the start command. You may have a situation where the PPS-100 is picking up the START signal and then losing sync with the tape machine.
This can happen with a read problem at the PPS-100 due to low or high level SMPTE strip to tape. In that case the PPS-100 will go into Flywheeling, AKA free run, or free wheel (as JP mentioned). That happens when the PPS-100 can no longer make sense of the SMPTE info.
The PPS-100 manual is not very well written if you have no other experience with SMPTE. I think it assumes (wrongly) that people will be coming with some sync background. I like the J.L. Cooper products… I have both the PPS-1 (version 2) and the PPS-100, but the manuals are a bit too brief for the uninitiated.
The manual also wrongly states that you should run the signal through the mixer to tape, and that you can leave noise reduction on. I wonder if this was a marketing call on their part (They knew better). A lot of cassette multitracks were coming out that didn’t have the ability to disable noise reduction on the sync track. You could get away with it sometimes, but it’s not considered good practice… not reliable. dbx and sync is an absolute no, no.
The record level should be about –7 dB going by the LED meter on the TSR-8 (That’s the level I use with the J.L Cooper units). I’m wondering where you’re getting the +10 figure. The TSR-8 meter only goes to +8. The best way to set it is to turn the switch on the back all the way to your left (If you're facing the front of the TSR-8 or think of it as all the way towards the input/out RCA jacks). Then use a small screw driver to adjust the level on the back of the TSR-8 until you have –7 on the LED meter for track 8.
Are you sure dbx was off on Track-8? You have to push the Record-Ready button for track-8 before you hit the Sync-Lock button to disengage dbx on track-8. Of course if your not using dbx at all this doesn’t apply.
Another problem could be hot levels on Track-7, which can bleed through to channel-8 and cause sync read problems.
I don’t know Cubase that well. I had Version 1.xx.something a few years ago. I don’t know what V4 can or can’t do.
Some DAWs are better at sync via MTC than others. By DAW (Digital Audio Work Station) I mean PC (or MAC), Audio/MIDI interface and recording software. Sync problems can occur with any of these components of your DAW, or the sync device itself.
I run a PC-based DAW, using an Echo Layla and an older version of Cool Edit Pro (which I find to be more stable and less cumbersome than newer versions.
ATR/SMPTE to DAW via MTC runs flawlessly with either of these configurations… perfect sync with either my PPS-1 or PPS-100 like you have.
One other thing… before continuing reinitializes the PPS-100 (just in case it’s the problem).
To initialize, turn off the power. Next, hold in RUN button and turn on the power.
This puts the PPS-100 into a self test mode. The red LED will flash and some codes will
appear in the display). After 5 seconds, turn off again.
![Smilie :) :)](/images/smilies/smile.gif)
