doctornads said:
everything is stock setup from gibson. Not that that would mean anything. Neck is straight the nut i dont know what are you asking about that. And the action is good. not too low and too high.
Factory setups are NEVER right. Take your guitar to a good repair person, and get it set up. It is clear that you don't have the experience, and this is not the guitar you should be getting it on.
The neck shouldn't be straight. It should have a bit of bow in it (fret at the first fret and a fret near the body, and see how much of a gap there is between the bottom of the string and one of the middle frets - it should be about a playing card's thickness). As for the nut, I've never in my life seen a factory made nut which didn't have its slots too high. This in particular is not something you want to try to adjust yourself, because if you mess it up you need to take the nut out (to either shim or replace), but with Gibson's practice of lacquering in their nuts, you can cause some major cosmetic damage if you don't know what you are doing. THEN you set the action, and with a tune-o-matic you then need to set the height of the tailpiece. You need downward pressure on the saddle, but you don't want the string to touch the back edge of the bridge. It is only after all of that is right that you can start to worry about the intonation, because you won't be able to set it properly if everything else is not right.
But you also need a good tuner to set intonation, and that means a Strobe. Getting all the tools to do a setup properly is quite expensive, and gaining the experience and knowledge on a rather expensive guitar is just not the best of ideas. If you really want to learn, buy Dan Erlewine's book on the subject, and start by practicing on something cheap.
Light
"Cowards can never be moral."
M.K. Gandhi
