V
Valentino_nl@
Hi,
I imported a Midifile in my SONAR VS sequencer software. Usually i play all my Miditracks to my Roland Keyboard and then I can record the result to an Audiotrack through the Line-Out of the keyboard. This works fine.
However, now I want to record Miditrack 1 which contains the lead-instrument, to a separate Audio track using the Roland TTS-1 SoftSynth. I added a single TTS-1 Softsynth to my project and checked these settings : First Synth Audio Output + Synth Property Page.
Settings Midi-track 1:
Input: Alle inputs - Omni
Output: CakeWalk TTS-1 1 Channel 1, Bank: 154 (default) , Patch: Harmonica
Settings TTS-1 :
Input: All Inputs - Omni
Output : VS100 OUT 1-2 Channel: [None] , Bank: .. , Patch: [None]
Track TTS-1 'Armed' for recording
This happens :
Both Miditrack 1 and TTS-1 show an output signal and I can hear the lead instrument of track 1 play though my monitor speakers (the other instruments play over my keyboard).
Though nothing is recorded on the TTS-1! During recording the pointer moves over the track and shows a color but no signal is recorded.
I also tried to add a separate Audio track but then i either coudnt point the output to this track or coudnt arm the track or nothing was recorded.
Does anyone have a clue why this cant be recorded or how I can fix this?
Thanks in advance for your reply,
Valentino
Settings TTS-1 :
This happens :
Valentino
