HomeMadeHitShow
Member
I'm not sure if this is a MIDI problem, soundcard problem or software problem so I'll start here.
I just got a new soundcard (Delta 24/96) and set everything up. I am recording using Acid 5.0, a MIDI Keyboard and Steinberg The Grand soft synth.
When I record the MIDI and playback the MIDI track it sounds great. However when I use ACID's option to convert to WAV or when I convert my whole song to WAV the piano sounds get all messed up. Basically they cut of too soon,
Imagine you hit a C piano chord and keep your fingers down, it keeps sounding correct, that's how it sounds when I playback the MIDI, however on the convert to WAV the sound cuts of a short time after I press the keys
Any ideas ?
Thanks
Tony
Any ideas ?
Thanks
Tony
