pro tools LE Problem
  • Thread starter Thread starter cobradenim
cobradenim
cobradenim
All Of a sudden, the Audiosuite doesn't work. Usually, you highlight or select audio, then select your plug in, then "process" the audio. Then it will create a new region with the new audiofile that has the effect applied.
Well, all of the sudden, mine doesn't do that. When you hit "process" the box comes up with the blue line that shows the process so far but that is it. It doesn't create a new region with the new audio. However if you go to the "edit" tab and pull down, you can "undo compressor" or what ever effect you tried to process. The thing is, It didn't do anything. No regions were created and no audio was "processed".
I cannot figure it out. The Protools reference guide says nothing about it. If anyone can help, it would be greatly appreciated.
Thanks
you need to change the option in the Audiosuite plugin to say "use in playlist"
Thanks alot! It now works! I must've selected it my mistake.
