JazzMasterWil
First and foremost, whoever came up with idea of a newbies forum is a genius.
I for some help over at the harmony central forums and one guys response was "buy a couple grams of snow and a patchbay"..... I also had a guy respond "Are you just making quick demo's? If so - save your cash for real studio time"............ I just had to let it slide... If they don't think you can make a great cd at home for cheap (*coughs* FUGAZI *coughs again*) that's their problem.
Anyways I'll let down to the point here. I have a somewhat nice setup now. It's a tascam dp-01 8 track recorder. I love the unit and it's very simple to operate.
It's superb as far as running a drum machine into it, and playing guitar and bass into a pod, and then putting a vocal track down..... It doesn't get much easier than that.
The problem is that it can only record two mics at a time and that it doesn't have xlr inputs. If you're a newbie reading this. PLEASE buy a recorder with XLR inputs. You will thank yourself for it later.
So to even run one mic, I have to plug the mic into the mixing board and then send a line off the mixing board into the tascam. This isn't such a huge pain in the butt, expect for the nightmare that we call "drums".
Basically I run every last drum mic (expect for the snare drum) into a 24 channel mixer. The signal off of this mixer goes into one input of the recorder.
The snare mic is run into a much smaller mixer and goes into the other input of the recorder. I do this so I can have the snare on it's own separate track and adjust it's level by itself.
Ok the problem is that I record all by myself. And I have to use the "guess and check" method. So basically I mic everything up, record it, make small little adjust on the mixing board, record again, listen to it, make small little adjustments on the mixing board, record again, listen to it, make small little adjustments on the mixing board, record again, listen to it, make small little adjustments on the mixing board, record again, listen to it, make small little adjustments on the mixing board, record again, listen to it, make small little adjustments on the mixing board, record again, listen to it, make small little adjustments on the mixing board, ............... realize that one of my overhead mics is in the wrong position and then I record again, listen to it, make small little adjustments on the mixing board, record again, listen to it, make small little adjustments on the mixing board,record again, listen to it, make small little adjustments on the mixing board, ............................... It makes you want to pull your hair out just reading it doesn't it?
Anyways, I have seen the light as far as needed a computer based system is concerned.............. I'm not very good with computers and get confused by technology pretty easily. So please be patient with me.
I really need a system that will let me record up to 4 mics at one time. I know that's a good number of mics, but it's the least I could get away with. (That's 2 overhead, one on the snare, and one in the bass drum).
If I could make adjustment to channels while listening to the play back, that'd really help me out. (Instead having the nightmare of "guess and check" again).
I would like to have a program that I could get a lot of cheap (or even better, FREE) plug in's for. I'd love have reverb, compression, an eq, and all of that good stuff just a click away. It'd make life a lot simplier, and it'd be a lot cheaper than going out and buying effects units, compressors, limiters, eq's etc...........
I'd really like to try pro-tools free, or an similar inexpensive program. But I don't even know what I'd need. I mean I get that the computer would record the music, but what do the mics plug into? (And more importantly how much does it cost).
If I bought this "microphone to computer" thing-a-ma-jig could I only use it with pro-tools free?
Or could I use it later on down the line if I decide to upgrade to a different computer based recording system. (Perhaps pro-tools the not-so-free version or something).
I have a couple years of recording experience under my belt, but untill now all my stuff has just been in the "songs for fun" and "sappy little songs to give my girlfriend to listen to" categories.........
And now I wanted to make a pretty serious demo that could get my band a couple gigs. A drum machine is not going to cut it, and if I have to even type "guess and check" one more time (after that last one of course) I'm going to pull all my hair off and move to a desserted island somewhere off of Fiji.
Any and all help would be greatly appericated. I love recording and I really want to "break into" the computer based stuff, but I'm on a very limited buget. I can spend 500 at the most and that's including the mics-to-computer-thing-a-ma-jig (pardon all my technical lingo)
THANK YOU VERY MUCH IN ADVANCE!!!!!
