L
LukeDrum44
Since I bought Pro Tools 9 I've normally always had my output as the two speaker monitors, but recently I decided to save some space on my small desk and change to the built-in output on my iMac. When I do this and create an audio track on Pro Tools to record, it doesn't recognise the audio interface for some reason. When I click the input drop down on the track and go to 'interface' there aren't any options from that menu.
If I plug the speaker monitors back in through the audio interface and change the output options, I can choose the input correctly and arm/enable the track to record.
I made sure I had the latest driver for my Audio interface and updated to Pro tools 9.0.6 and then re-installed pro tools 9. I still have the same problem.
The audio interface is the M-AUDIO MobilePre USB but I don't think that's the problem.
When I get to I/O setup from the tool bar there is nothing set but I can't choose any of the options like 'New path' etc because they are all greyed out.
The only ones that arent greyed out are the ones down at the bottom - 'Import settings' and 'Export settings'
I can click import settings and choose Last used for example but when I set the input as 'in 1' and try to arm the track/enable record it comes up with the message 'the track could not be record-enabled because it doesn't have both an active input and output assigned'
Has anyone had a similar problem or have a solution?
Thanks
Luke
Thanks
Luke
