T
tddrummer
Is it an excepted technique to run drums through a preamp..for instance overheads one channel...kick...snare...toms etc...Or do you just ad compression and things later on? Just asking
On the things I record on (analog and digital) pretty much anything that requires a mic requires a preamp, even if it's the on board 'trim' which I guess is the 'in house' preamp. When you set the preamp, push or hit whatever the preamp is boosting as hard as possible and gradually decrease the preamp gain until there's not even a hint of clipping. For me, whatever I add, I add after the event.Is it an accepted technique to run drums through a preamp..for instance overheads one channel...kick...snare...toms etc...Or do you just add compression and things later on? Just asking![]()
