Can anyone who has experience with these two preamps give me an idea which might amplify an EV RE20 more effectively? This is for voice work only.
I used to have a Mackie 1202VLZ but needed to crank the trim to near-max to get sufficient signal. Even then I had to use the output gain on other gear to help some, and it was somewhat noisy.
The Mackie is out of the picture now (it was borrowed), my budget is around $150, and I don't have the option of auditioning gear where I live. Online reviews and this forum have steered me to the VTB-1 (spec'd at 72dB gain) and the DMP3 (spec'd at 66dB gain).
It comes down to: Which preamp will give me the most gain? and Should I go by specs alone on this? Better yet, has someone used both got an opinion or recommendation? I realize they must be close, given the generally-positive opinions on them, though differently "colored" some. Color is not an issue, and might not be something I could tell very clearly.
Thanks for your comments and experience.
James
James
