I went to the First Act website.
The only microphone I could see there was the MVM84.
See:
http://shop.firstact.com/PublicStore/product/Professional-Vocal-Microphone,277,95.aspx
I'm not sure that it's the same or a similar one (it's more expensive and has a different catologue number).
It's advertised as a dynamic mike.
The chances are high that what you have is also a dynamic mike. That makes sense if you can plug it into your amp and get signal from it.
That means you don't need to power it up, nor do you necessarily need a pre-amp.
That also means that the problem is not with the mike, but with the connection some where between mike and computer, or with settings within the computer.
I gather that you are using the 1/8 mike input on your soundcard? Which means you have an adaptor. Adaptors are simple and fairly robust, so that shouldn't be the problem. However, it is worth trying a different one if you have one laying around.
It is worthwhile going into your computer, into the control panel, into sound and audio devices, click on the 'audio' tab and check the recording settings to make sure that particular input is not muted, or has the volume turend right down.
