Power amp question
  • Thread starter Thread starter Kevin Deschwazi
Kevin Deschwazi
Kevin Deschwazi
I understand the need for an accurate monitoring system for mixing and I think I have a good grip on what makes a speaker appropriate for this (flat response, no colouring of the sound like with hi-fi speakers).
In all of my reading I've not noted that the power amp doesn't get mentioned too often. Am I correct in thinking that the amp could potentially 'colour' the sound also? As such do manufacurers produce 'accurate' amps specifically for monitoring?
If so any suggestions?
Also I'm aware that active monitors may be the best option but is this the most economical?
ie. The Tannoy Reveal actives are £350 whereas the passives are £150. Am I going to get a decent power amp for much less than £200 (roughly US$370).
Thanks
Hafler makes an "entry level" TransNOVA class amp.
Can't remember the model number... I should... This amp comes up frequently...
It's arguably the ONLY amp I'd suggest in this price range.
John Scrip - www.massivemastering.com
Thanks very much.
Looks like the P1000? (There are also more powerful P1500, P3000 & P4000 models).
Another possible addition to the ever expanding "stuff I need to get" list.
Amplifiers can color the sound. Cheap amps can wimp out when trying to produce high current bass signals, and they can generate a good deal of distortion when driving a real speaker load.
$370 is definitely on the low end for a decent amp.
The amps inside most lower priced active monitors are shit.
Thomas
________________________
Thomas Barefoot
Barefoot Sound LLC.
Recording Monitors
