J
Jan
Look at the specifications of a SM57. At 6000Hz, a huge presence peak of about 7db (very unpleasant frequency for recording). At 15.000Hz the level is already more then 12db lower then that peak!
SM57 Sensitivity: 1.9mV
www.shure.com/pdf/userguides/guides_wiredmics/sm57_en.pdf
Compare this to a mainstream low budget condenser like the AKG C2000 and you will see a completely flat response with a mild boost at about 11.000Hz and still almost flat at 15.000Hz
C2000B Sensitivity: 20mV (ten times higher then the SM57)
www.akg-acoustics.com/english/microphones/index.html
Go to C2000B then Specifications
Compare this to the highly praised TLM103
www.neumann.com/infopool/mics/produkte.php?ProdID=tlm103
Go to Tech data and Diagrams
TLM103 Sensitivity: 21mV
Basically this means that:
The specifications of a cheap condenser like the C2000B are already very high (compare them to the TLM103). The low sensitivity of something like a SM57 calls for high gain pre amplification, which, as we all know comes at a high expense.
The C2000B has an output that is equal to the TLM103. Plugged into a crappy mixer, you won’t need to turn up the gain half as much as the SM57, resulting in much lower noise!
I repeat what I mentioned before: The SM57 is not an all-round recording mic. It is a typical live mic or a nice mic that you use in the studio for snare drum etc.
If I have to mic a guitar cabinet I still prefer a good condenser over the SM57
Please remember that I own the SM57B, C2000B and TLM103
Put them on a pole next to each other, plug them into a mixer, put on headphones and try the difference. If you can’t hear it, please stay with the SM57, or go and get your ears checked by a very good doctor!
The SM58 or SM57 is the mic that I always advise to any beginning band, playing live, but if I would have to do it all over again on a small budget and I could afford just one mic, I would go for the condenser.
Best advise for the beginning recording artist:
Don’t buy any mic! Try and borough it from a friend with more money. I always did that when I was young
If you play live, you already know the SM57 or SM58, but please remember that any vocal or instrumental recording will improve dramatically ones you upgrade to a condenser.
An airy vocal sound with a SM57? Forget it!
If you want to do construction work, don’t use your microphone, buy a hammer. Even though I must admit that the SM57 sounds very close to that.
Jan
Jan
